What is this and how do I use it?
I got this is a box of parts. HOW do I use it?
Sent from my SM-G920V using Tapatalk
I have a 2.4 p2, 5.8 p2v, no camera on 2.4. Is it for extended range for video or for rc?
It's for your P2V to boost your repeater .
Reactions: dirkclod
Reactions: dirkclod
Ok very nice. Now what meter do you use to make sure they work and where do you get one?
Definitely not for video, most, if not all video uses 5.8. I think I saw a mod somewhere using an antenna like that to mod a P2 controller, since it uses 2.4.
So just plugging the antenna into a WiFi extender (outfitted with the jack) won't work? I acquired the antenna along with some fat shark stuff along with a damaged immersion 600 mw (I guess transmitter) and wasn't sure if antenna works as a stand alone. What's the easiest way to test the single pole antenna vs the big tp-link?
P2V uses 2.4 for video = TP-Link
The P2nv uses the fat shark and immersion witch is 5.8
Reactions: kenjancef
It does? It doesn't use the same system as a P3A or P3P?
No . Just like a P2V or Plus .
Totally different animal then the other's .
So I can plug the tp-link into the small sma connector on this wifi extender and I should get better distance the the stick antenna that I currently use?
