- Joined
- Jan 8, 2017
- Messages
- 94
- Reaction score
- 6
- Age
- 7
Had to roll back to this because of some battery errors. Can I use this version? Should I attempt to roll back up the firmware ladder instead (avoiding the latest firmware)?
Make sure the battery is pushed all of the way in. The P4 will start in some cases if the battery is not all of the way in but this error will be returned. Most likely this was your issue.I was getting "battery signal error". I have since updated to the firmware just before the last one. No battery errors now. I suppose I'll stick here until another update comes out.
I'm confused. You went _back_ to this firmware already and wan to know if you can use it? If you rolled back to it, are you not using it? You then want to "roll back up"? I have no idea what that means. Are you asking if you can go right to 1.2.602?
I had the same problem. Took 2 months and a lot of back and forth with DJI but they finally replaced my battery out of warranty.I was getting "battery signal error". I have since updated to the firmware just before the last one. No battery errors now. I suppose I'll stick here until another update comes out.
