Taking off from truck bed
Is it safe to take off from the bed of a truck or will that mess with the signals and compass?
It's not a good idea to take off near any large magnetic metal objects.
From the Phantom manual:
Reactions: Bull94
Same thing with the new aluminum f150?
If the truck is 100% aluminum (which I highly doubt), then it should be fine.
Reactions: Bull94
This will give you compass error that will cause the phantom to fly erratically.
Reactions: Bull94
It still has a steel frame.;)
Reactions: Bull94
Great, lol my plan was to be able to use a bed cover to take off and land from which would help when there's nowhere flat to take off and land from. I was thinking it would especially be great for the inspire since I read it needs to be on a flat surface before take off to calibrate?
With an iOS device, you can use the TeslaMeter on this free app to check for magnetic interference: Multi Measures 2 - The all-in-1 measuring toolkit on the App Store
If you must take off from an area giving you a compass error and can't change your take off point, then you can try raising you take off point using a tall plastic bin. A last resort could be a risky standing hand release take off.
Reactions: Bull94
Awesome thank you for sharing that.Are there any specific ranges of interference I should be on the lookout for?
Should be only a few feet ....My take off points are often from a concrete parking structure with highly concentrated sections rebar in it. Moving my take off point just a few feet will eliminate the compass error.
DonT
