wkf94025 said:I have not made any mods to the P2 with respect to onboard flight controls. Stock receiver, stock antenna length and routing. I am curious to install the Futaba receiver and longer antennae, but that's not a high priority at the moment. The video Tx is the ImmersionRC 250mW mounted in the typical position underside on the belly, near the back, on the centerline of the 'fuselage' with the connector facing aft. The antenna 2" extension bends down ~60 degrees, and the SpiroNet antenna connects from there. I have been playing with SpiroNet on the centerline, versus rotated away on port side, to "peek" around the hull when the video RX (googles or Lilliput) are off the nose of the ship. Not sure yet what is optimal orientation.
Pics soon, but nothing special going on here. Next expirment is using $20 patch antenna on Fatsharks instead of SpiroNet.
Kelly
Makes sense. Pics probably optional as it is stock with respect to the receiver. I thought you had the Futaba receiver with the extra long antennas. But vTX routing and positioning does make a huge difference on both FPV and RC range so that could still be interesting.
