How do you set anew RTH altitude? I have tried several times ant it won't set the altitude.
Thanks
Thanks
What have you tried?dub3 said:How do you set anew RTH altitude? I have tried several times ant it won't set the altitude.
Hpdb301 said:mine wouldn't take either until it was connected via wifi to my Phantom. Once it was connected, everything worked for me.
flyNfrank said:Hpdb301 said:mine wouldn't take either until it was connected via wifi to my Phantom. Once it was connected, everything worked for me.
This is cool.... Fellow pilot registers to help someone get the right needed info.
I haven't tried it yet, but I believe I read somewhere that with the new firmware you could not mark a Home Point anymore like using the S2 option.
Btw, setting your RTH Altitude is really something you do based on your surroundings. I would suggest you set this height at something know will clear everything with no doubts. I also think this is something that will easily forgotten about. So....should you go somewhere to fly away from your normal area and then forget about your RTH Altitude settings, is a good reason to set it high from the get-go.
It will not descend, only ascend to the specified height. If it is higher than the specified height it will maintain that height.rickasaurus said:I would just like to be clear what RTH Altitude actually means. Does it mean that the P2 will ascend or descend to the specified altitude - above the home starting point altitude - before descending directly down to home point?
Thanks
Rick
phantomi said:It will not descend, only ascend to the specified height. If it is higher than the specified height it will maintain that height.rickasaurus said:I would just like to be clear what RTH Altitude actually means. Does it mean that the P2 will ascend or descend to the specified altitude - above the home starting point altitude - before descending directly down to home point?
Thanks
Rick
