Repurposing control channels
Hello,
I would like to use a Phantom 4 to take air samples using an on-baord pump. I would need to activate the pump in-flight. Is it possible to do this using the drone's own controller, or would I have to add a separate radio control unit? If necessary/possible I can remove the camera and use the control for that.
Any advice appreciated. Thanks!
Oh, I didn't know it has controllable LEDs. That sounds like it could work. Thank you.
Is it easy to take the Phantom 4 apart with a screwdriver (to get to the LED wiring), or does it have some kind of moulded casing?
Photosensitive switch would allow it to activate without wiring directly to led.
Turn on lights. Switch turns on. Activate pump.
Or search for the led spot lights kits that have remotes, about 80-$125.
Thank you for the replies. Just wondering, does the Phantom 3 have controllable lights as well?
irish_phantom
