Question PV2+
4wd said:
You need the different RC software, then plug in the controller and will tell you - probably not.
Thank you 4wd I downloaded the RC Software, I just had to calibrate the sticks and looks all okay, a weekend coming up so I can try everything out. I just hope it's fine in the old Sydney town, Australia. Thanks for your help once again.
Just an FYI, the proper procedure for stick cal is cal the TX in the RC assistant first, then connect your quad to the PC Assistant, turn on your TX, and cal the TX in there.
brianklenhart
