Problem
Problem? If you are seeing props in your frame try flying slower, if you are seeing shadows from your props try shooting with the sun lower in the sky.
When flying into wind, yes it's a problem. To mitigate the problem pitch the camera down to remove props in view. Sometimes you'll miss seeing the props, in which case you can opt to crop the video during post edit. The P4 camera is positioned 9mm higher in relation to the props, versus P3 craft, making the issue worse. Try shooting while flying backwards to mitigate the issue.
Using ND filters (ND16, ND 8) you can push your camera shutter speed down up to 1/50 sec - 1/120 sec (rule: shutter speed = 2 x fps frames per seconds) when props are really not visible in video.
Instead of making us guess, can you tell us what you mean?
Reactions: 1boater and Pharm
src72
