Post Firmware Update Question
Central Wisconsin
Hi all, a Newb here. I am inquiring if I can or should remove/un-install the firmware update from the MicroSD after the update has been performed?? Or, is it required to stay on the card to work properly??
You can remove it from your memory card after you have updated all of your spare batteries.
Reactions: flySwampAirWI
Sure. Fire away.
What is the USB connection, the one up further than the gimbal one on the body of the drone, for??
You can use that port to retrieve the DAT flights logs that are stored on the Phantom's internal memory card. If interested, you can find detailed instructions here.
OK Thank you for the reply and link. I will read that as soon as I have time. Is there a published owners manual that explains and instructs on the use of the drone?? The included manual leaves a lot to be desired.
Which Phantom do you own?
You can download the P3A manual here.
jorge sanchez
