What version of DjI GO Was you running?I tried to go back to 1.5.7 and was successful to getting back to that but when I went into the DJI Go app on my iphone I had compass calibration error, imu calibration error, gimbal gyro error and a barometer error. None would clear from recalibrating the A/C. The only fix was to go back to 1.8.10. Anyone else have this issue?
What was the fix? SirI've successfully downgraded!! Thank you everyone for this!!
Mike90 Please Understand that this is A P3S Post... And your asking P3P questions??Hello all !
How I can check version of RC's fw on android?
If im rightly understanding from 1.6 fw output power was reduced. How I can downgrade RC fw ?
(Im not beleive that its impossible ))
Thats prob the problem. That fw and that software was never meant to work together.
As It is... Never debug while downgrading... Only debug current versionsGood afternoon!
I apologize for my English since this is not my native language.
I have P3S firmware 1.8.1 DJI GO 3.1.3
Yesterday I tried to roll the firmware back to 1.5.7.
From 1.8.1 to 1.7.9 rolled back just by inserting a flash drive with the firmware file without DEBUG.
The firmware time was 10 minutes without problems.
Further on the flash drive threw the firmware file 1.6.8 and file DEBUG, did according to the instructions, inserted a memory card with firmware and DEBUG into the camera, turned on the RC and DJI GO further switched on the drone and went the firmware. At 1.6.8, the minutes were struck for 30 minutes making strange sounds)) before they were not.
At 1.6.8, it was successful, there are no errors, it's OK, the DJI GO version of the firmware is 1.6.8+.
Then I did the same with 1.5.7 + DEBUG, I turned on the drone, the drone was sewn too very long 20-30 minutes making sounds as if it turned on, the firmware stopped at 80% and gave out a message, "Unsuccessful update attempt" in DJI GO gives out The firmware version of the drone 1.5.7+
When you turn on, the drone gives a message about the need to update the firmware of the camera and gives a message about the need to calibrate the compass.
I tried again to flash 1.5.7 + DEBUG, everything repeats. Errors!
Tell me please!
Do I need to add file DEBUG to the firmware file when I roll back from 1.6.8 to 1.5.7.
Also, when I moved from 1.6.8 I stitched the file P3C_FW_V01.05.0070.bin and on the site there is still the firmware file P3C_FW_V01.05.0075.bin whether it is necessary first to flash P3C_FW_V01.05.0075.bin and then P3C_FW_V01.05.0070.bin
How now to be?
As It is... Never debug while downgrading.. Only debug current versions
I would refkash 1.5.7... then debug it... again.. then flash P3C_FW_V01.05.0075.bin then run cal in EVERTHING... If it doesn't clear errors?? Go all the back up... newest... then debug that... downgrade... then debug... downgrade then debug... back to 1.5.7... I have heard that skipping 1.6.8 is working for most?? Many you can confirm it for us...?? So this is the working way?? 1.8.1 debuged.. (no +) then 1.7.9 then debug 1.7.9 the 1.5.7 and then cal?
P3S P3/4K downgrade Possible !?! ALL the WAY back!!! (Confirmed Working to 1.5.7!!!) < Please read.. Only Debug current Version! I do not know the outcome of a debugged downgrade?? It has not been a part of any of my testing...Ok so let me get this correct, only use the debug file when going from 1.8.1 to 1.7.9? I thought you used the debug file wen downgrading from each firmware.....So essentially your saying only use the debit file once when downgrading from whatever your current version is. In my case its 1.8.1
Please note this is a P3P description...P3S P3/4K downgrade Possible !?! ALL the WAY back!!! (Confirmed Working to 1.5.7!!!) < Please read.. Only Debug current Version! I do not know the outcome of a debugged downgrade?? It has not been a part of any of my testing...
Ok well... The 1.6.0 F/w issue is P3P... Magic Power mod is what you are needing for the P3S.. You can change all R/C settings with itMy question for p3s
Hello!
Yesterday I spent the whole procedure from the beginning)))
Updated via DJI go up to 1.8.1
And then, downgrading from DEBUG to 1.7.9, everything went well, in the dji version of the firmware of the Copter 1.7.9 without +
Further the same way up to 1.6.8, all ok
From 1.6.8 to 1.5.7 already without DEBUG firmware
After rebooting the drone, compass and all the sensors work fine, calibrate, everything is fine.
But the firmware version is N / A.
Do I need to do something, or leave it as it is? Do I need to now firmware to 1.5.7 with DBUG, or can I flash 1.5.75?
Please advise how to be.
The App not showing a ver # should be an App Issue.. You should be fine?? But you may what to roll back DJI?? Maybe 2.9.1 > 2.4.3 ?Hello!
