Ok Thanks. Would you recommend P3 4K or P3 Advanced? I previously owned a Phantom FC40.That's not it. P3 4K is the same as P3S with 4K camera. It does not have Lightbridge like P3A/P.
I would get the Advanced for sure.Ok Thanks. Would you recommend P3 4K or P3 Advanced? I previously owned a Phantom FC40.
Thanks. So just to be clear, the P3 standard and the P3 4K are the same except for the camera? So the P3 Advanced is a better option?It is a pleasure to welcome you to the Phantom Pilots forum Jake. I hope that you will take advantage of the benefits that come with membership and that you will be able to use the forum for the exchange of innovative ideas and as a resource for current developments in Phantom quadcopter’s.
The P3 Standard & 4K are comparable and use wifi transmission.
The P3 Advanced & Pro use Lightbridge for transmission.
At this time DJI has the best system with Lightbridge. No one else can compare to that.
Wifi is inferior to LB so that is a big consideration when buying one. If I had a budget that included a LB model it is a no brainer, get the LB model so the Advanced or Pro should be on your radar.
Yes sir!Thanks. So just to be clear, the P3 standard and the P3 4K are the same except for the camera? So the P3 Advanced is a better option?
Check out DJI's comparison to view the specs side-by-side.Is the only difference the upgrade in the camera from the P3 Advanced to P3 4K?
