Fantastic. Please keep me updated. Thanksd4ddyo said:I have a prototype case using a pelican case being made. Pre-cut foam etc. Getting it this week.
mcmax20 said:Where are you getting the custom molded/cut foam from? I have a Pelican 1560 that works great and holds everything I have perfectly (with room for a Lightbridge! ). The only complaint I have is about the pick n' pluck foam, it works great now but for long term I know it'll degrade. I find the custom cases out there with molded foam don't make efficient use of the space available and I've spent hours on mine with the pick n' pluck to get it "just so".
Ksc said:mcmax20 said:Where are you getting the custom molded/cut foam from? I have a Pelican 1560 that works great and holds everything I have perfectly (with room for a Lightbridge! ). The only complaint I have is about the pick n' pluck foam, it works great now but for long term I know it'll degrade. I find the custom cases out there with molded foam don't make efficient use of the space available and I've spent hours on mine with the pick n' pluck to get it "just so".
put this in your 1560: http://www.thepelicanstore.com/Kaizen-1 ... -1437.aspx
