Does anyone know if there is a gimball that will work with a GPHero+? It has the non removable case. Hoping there is a gimball that allows you to use the standard go pro mount.
I was told I was buying a GP hero3 then when I received it, it was the GoPro hero +. Which I can return but was hoping to find a way to get it to work. Otherwise I am looking at an ilook+ but recently found out they don't have their own power source which then only can be used with the P2 and not as a stand alone action cam. Sort of a I want my cake and eat it too. I don't want to fork out 3-400 bucks for a camera......Spending hours on the web today I came across the dazzne P3 cam and eken HD. But not sure any of them will fit the gimball I am looking at (walkera G-2d). Yes I know this stuff is cheap Chinese stuff but I think it will get the job done until I can part with the cash for the "good" stuff.
I own 4 GoPro two of which I paid retail while the other two i bought used for half the retail. Scan ebay for either a hero 3+ black or the hero 4 black but stay away from the hero 3 as they had nothing but problems.
I am currently testing a hero+ on a Chinese gimbal.
So far the biggest problem mounting it.
Either u modify the arm that holds camera or remove the bottem swivel bracket ( cut / hack it off) of the housing.
The reason is that it just sits to high on the gimbal which doesn't allow for travel.
The second is that none of the standard Velcro straps work to hold in place. I got it working with zip ties.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
