Hello everybody, this is my first post and I appreciate the help I have already discovered on these boards. With that said - I will explain my issue. I purchased a Phantom v.1.1.1 on ebay. It did not come with a Tx. I bought a DJ6 transmitter from amazon pretty cheap. I binded the Tx and Rx with the sync button on the internal board inside the quad. When I startup the Naza assist software everything looks good I can see the stick movements from the remote. When I turn the Tx off and on the Quad responds with LED (so it appears to be bound). The issue is when I unplug the USB and get the quad ready to fly.. the Tx isnt spinning the motors or making the quad work at all. I have tried DBUS and PPM. It only works on DBUS (also have the 2 wires/antenna coming out of the bottom for DBUS). The transmitter has a solid red light after the original bind.
As I was writing this I looked around the Naza software some more and ran into the motor test tab. It looks like 3 of the motors will do a very brief turn as I test, except for one. It seems to be shot. Would having one bad motor cause this issue from above?? Thanks in advance!
