Minor cell voltage deviation
jttt777, it's normal for the battery cells to vary slightly during the entire flight. The thing you want to watch out for is a high number of large variations (greater than 0.07V). If you upload your log here, you can see more information about the battery cells.
Looks pretty normal there, was never above 0.07V
DJI Phantom 3 Log Viewer - Phantom Help
Hey one other question, it says GPS Atti, I assume that is the same as GPS? I was in the top most position on the switch, should have been using GPS not Atti. The name is confusing....
Yep. Looks good.
Do you recall if you were flying in ATTI mode at the time? Even though you were in the top position, your Phantom will still auto switch to ATTI if it is not able to use the GPS data and/or is not able to use the compass data.
Msinger, how do I access my log file to upload into the link you provided? Just not sure how to save a log from healthy drones using an iPad.
Yep. Looks good.
I was definitely flying in P-GPS mode, not P-ATTI. I don't think this program you have might read the mode right. I tried to reply in DJI Go and it clearly shows P-GPS and my screen always showed P-GPS and never switched to ATTI mode while I was flying....
Others have noticed the odd modes too. I think it's just a bad translation of the flight log data. I'm going to do some detailed testing this week to see if I'm able to come up with a better translation.
I know how to upload my logs into healthy drones, I thought you had provided a link to upload those logs to see even more information about your batteries.
I must have misunderstood your post.
I don't want you to upload to Healthy Drones. I was simply providing instructions to help you retrieve your TXT log so you can upload them to my log viewer (since you asked me how to do it). Perhaps I misunderstood your question?
So if I full charge my both batteries, everything is ok in the app, all cells show the same level of juice, what could be the problem, that when I put load on the battery /not start engines, but take off/ all cell turn yellow even 100 % charge. Flight however no problem- regularly landing on 20% cancelling RTH. Please advise.
Please upload your flight log here and post a link back here.
rockymountaincaptures
