Couldn't I set my max altitude to 200'? From take off point.
That would work if you know that the ground only drops by 200 ft once you are off the mesa.
But it is limited by firmware so the only answer you need to give is that it can go to 500 metres.
The rest is unnecessary complication to the people casually asking you how high can that fly?
Correct - that would require both a digital elevation model (DEM) for the terrain plus a database of all structure heights, potentially even tree heights etc. The DEMs exist, although would be a bit of a memory hog, but I'm not sure the structure database even exists.
There are things you should be concerned about and things you don't need to worry about.In this scenario, wouldn't you have to descend to the point in blue if you flew over that cliff, to comply with FAA guidelines?
All of which becomes irrelevant in a legal scenario apparently, since we must yield to actual aircraft always.
So unless you want to feel good that you are flying legal, because I have no idea how else you'd get pinned for it, it doesn't matter so long as you don't hit planes. Which in theory is why you'd stay under 400ft or whatever the limit is. Buuut, some aircraft ignore this rule or there might be some exploit you don't know about, so you could be flying legally in your mind and still be at fault for a wreck?
Am I wrong about this?
I'm not sure where you got that idea from. It doesn't make any sense
At ground level is ground level.
About 3 seconds on Google will show that AGL is Above Ground Level.
Or to see what the FAA says: Definitions
Or: http://atbasics.faa.gov/secured/pdfs/SLP 01-Resources.pdf
Your app does not give you AGL anything.
It's telling you how high your Phantom is above launch point which is not AGL unless you are somewhere flat.
In my illustration the phantom's altitude (agl) is how high the Phantom is above the ground (which is below it) and where it was launched from is irrelevant.
The term above ground level is self explanatory and shouldn't need any explanation.
But if you need it spelled out try this:
What is the difference between Above Ground Level and Above Field Elevation?
NRJ this sounds like the earth is flat argument of yester-year. The reason they have pilot licences is to learn and understand what the instruments are telling a pilot to fly safely. Likewise understand the limitations of the Phantom Instruments - the app, its telling pilot height above or below take off point (as you appear to have confirmed) NOT height above ground (AGL). The app gets this info from a Phantom built in barometer that measures air pressure, it has NO concept nor tries to understand height AGL, only height (air pressure)change from take off point.
Now back to fly off mountain example - the air pressure is same (for purposes of this example) when a Phantom flies sideways away off the top or side of a mountain, so displayed 'height' on DJIGo app will stay same, but we know that the phantom is actually now possibly hundreds of feet above the valley below the Phantom (AGL), and quite possibly flying way above legal / recommended flight height. Make sense? hopefully.
That's a good point.There is a whole world out there of aircraft that can't read true agl either.
Another reason pilots read sectionals - local ground elevations. Gets more complicated for pilots on long legs, barometric pressure can change enough to affect the readings and mess up your estimate of how high above the runway you are. That's why towers usually give pilots local pressure when they call in so they can adjust the altimeter to local pressure thereby correcting altitude. Obviously, not a problem for Phantoms, we usually don't have the bird up long enough to be affected by any changes in atmospheric pressure.That's a good point.
In general aviation, most small planes have a barometric altimeter just like our Phantoms.
They calibrate it to give a reasonably accurate altitude above sea level (so they can relate their height to mapped mountains etc.
But when it comes to agl heights they still have to work that out themselves, just like a Phantom pilot.
This thread is a flyaway with all of these 400' comments.
Hypothetically speaking, I suspect the Phantom could climb to the point it didn't have enough battery to land.
SB
