here some TX output comparisons, the inspire output sais 9w and the P3P sais 1.3, the standard 300mah
does the inspire really have that much more output power?! they both claim 5km
REMOTE CONTROLLER
Name C1
Operating Frequency 922.7~927.7 MHz (Japan Only)
5.725~5.825 GHz
2.400~2.483 GHz
Maximum Transmitting Distance Up to 5 km or 3.1 miles (unobstructed, free of interference) when FCC compliant
Up to 3.5 km or 2.1 miles (unobstructed, free of interference) when CE compliant
EIRP 10dBm@900m,
[email protected],
[email protected]
Video Output Port USB, mini-HDMI
Power Supply Built-in battery
Charging DJI charger
Dual User Capability Host-and-Slave connection
Mobile Device Holder Tablet or Phone
Max Mobile Device Width 170mm
Output Power 9 W
Operating Temperature Range -10° to 40° C
Storage Temperature Range Less than 3 months: -20° to 45° C
More than 3 months: 22° to 28° C
Charging Temperature Range 0-40° C
Battery 6000 mAh LiPo 2S
Yes output power too is 4 times that of non lightbridge, which is why it has a bigger battery, its all here and of course the frequency is 5.75 ghz on non light bridge and 2.4ghz on light bridge ones, power on 4 the output is a bit more 23db
Voltaje de Funcionamiento 1.2 A @7.4 V
Phantom 3 standard
MANDO DE CONTROL REMOTO
Frecuencia 5.725 GHz-5.825 GHz, 922.7 MHz-927.7 MHz (Japón)
Distancia Máxima FCC: 1000 m; CE: 500 m (En el exterior y sin obstáculos, altitud de vuelo 120m)
Temperatura de Funcionamiento de 0°C a 40°C
Batería 2600 mAh LiPo 18650
Transmisor de Potencia (PIRE)
Voltaje de Funcionamiento 600 mA @ 3.7V
Voltaje de Funcionamiento 300 mA @7.4 V
BATERÍA DE VUELO INTELIGENTE
Capacidad 4480 mAh
Voltaje 15.2 V
Tipo de Batería LiPo 4S
Energía 68 Wh
Peso Neto 365 g
Temperatura de Funcionamiento de -10°C a 40°C
Potencia de Carga Máx. 100 W
4k phantom
Frecuencia
- 5.725 GHz-5.825 GHz
- 922.7 MHz-927.7 MHz (Japón)
Distancia Máxima
- FCC: 1200m
- CE: 500m (sin obstáculos ni interferencias, 120m sobre el punto de despegue)
Batería 2600 mAh LiPo18650 2S
Soporte para Dispositivo Móvil Para tableta o teléfono móvil
Capacidad 4480 mAh
Voltaje 15.2 V
Energía 68 Wh
Peso Neto 365 g
phantom 3p
Frecuencia 2.400 GHz-2.483 GHz
Distancia Máxima Hasta 5 km ó 3.1 millas (sin obstáculos ni interferencias) Según normas FCC. Hasta 3.5 km ó 2.1 millas (sin obstáculos ni interferencias) Según normas CE
Batería 6000 mAh LiPo 2S
Capacidad 4480 mAh
Voltaje 15.2 V
Energía 68 Wh
Peso Neto 365 g
phantom 4
Frecuencia 2.400 GHz - 2.483 GHz
Distancia Máxima Según normas FCC: 5 km (3.1 millas);
Según normas CE: 3.5 km (2.2 millas)
Capacidad 5350 mAh
Voltaje 15.2 V
Energía 81.3 Wh
Peso Neto 462 g
