Looking for somebody who can repair my P2V+
Hi,
I would like to know if theres anybody in the forum who can repair my PV2+ V3. The problem is I cant sync my remote control with the Phantom. Hit me up if someone can help me.
Thanks
is that your only issue? pairing a RC with a Phantom? have you tried this procedure? I've done it many times
https://www.youtube.com/watch?v=jYic0Z6fZ8w
now, since the Vision remotes (not sure the part#) and the non-Vision remotes (DJ6 or NDJ6) run on different frequencies, you need to make sure the RC you're pairing is indeed compatible... a DJ6 or NDJ6 will not work with a Vision series P2
I did the procedure and I even called customer service of DJI and they said my phantom needs repair.
You might get that from them if all you needed to put new battery's in something :roll: If you could be a little more specific
on your problem it might beable to be fixed here !
You leave out just what has happened , if the TX is the one that came with it ,if it worked before and if so just what went on up to this issue > More info maybe ?
