Life expectancy
I only have 23 charges on my three batteries, and all three show 3 solid and 1 blinking led when I do the hold button test. So out of the three batteries I did a test on two of them, and discharge them down to 4%. Then I recharged those two batteries and tried the same hold the button test, same 3 solid 1 blinking. So deep cycle on the two batteries did not restore back to 4 solid LEDs, which I used to get. Will try the same deep cycle on my thrid battery, but I don't expect to see 4 LEDs..
What are the actual battery voltages as per DJI Go app?
Something isn't right as you may well know :) what are your cell voltages for your batteries full then at say 10%?
Also I found out by accident that deep cycling my batteries below the 8% DJI used to state does weird things to my P3P smart batteries!
I took my 4 batteries down to 3-4% and they where wonky afterwards. In all cases it reduced my subsequent flight times, on one of them I only got 10 minutes out of a flight! Was getting about 15 min out of the other 3 on thier first flights after the deep cycle. After 3 more normal charges from 10% (I ran them down to 10%) the flight time is pretty much back to normal and all the batteries reach 98-100% after charging and my flight times are normal around 20 min.
Same as batteries 1 and 2. 3 solid one blinking..
Battery Life cannot be reset or restored. Batt. Capacity may be able to be improved from time to time by cycling techniques.
The last I recall is that batt. life is based on charge/discharge amount not uses or charging occurrences.
+1
After doing deep cycles the batt. life will sometimes go up 1-2 % which tells me the capacity is in the equation.
Reactions: N017RW
I assume the guy with 99% life is running older firmware? The new firmware decreases steadily. There is no way you have that many flights and 99 or 98% life of battery...sorry! Lol
Sent from my SM-N930F using PhantomPilots mobile app
Here is the photo upto 1901km in 134 flights
Every flight average around 25,000ft - 40,000ft all long range.
NO, No, no ... I was referring to the fact that HealthyDrones indicates that ALL of your recorded hours flying were videos and NOT ONE photo snapped with your Phantom!
Reactions: N017RW
