Is anyone able to use ipad mini 4 with the new P4
I bought an iPad Mini 4 specifically to pair with my P4 and been utterly delighted with the relationship ever since. What is the problem you have? The two are made to be together.
My mini 4 will not pair. I online chatted with DJI and they said it is not capatible with the mini 4 and they didn't know when an update would be available. That didn't make sense to me.
That is bull ****, I have had no problems with mine and it is current with all updates.
I also used mini 4 without issue until I got the iPad Pro ... Recommend you follow WWK888's advice
When you say trying to pair, you do know you should be plugging a cable between the ipad4 and the RC
No pairing required.
Thanks UK, I meant all I get when connect cable to rc, where it should say "connect camera" I get "how to connect"
I bought a new mini 4 about 3 weeks ago and it has worked perfectly . Love it
Download the Dji assistant for your pc and hook up your p4 to your pc. Also sync your flight logs and uninstall and then reinstall the go app.
I believe they just mean it's not on their recommended device list.
I use my iPad mini no problems pairing but when flying my screen on the iPad is pixilated / and screen goes green and lags until it catches up. any suggestions?
ipad 4, phantom 4 working flawlessly here. I will confess, there was one time where they wouldn't connect. After several re-boots, I realised I hadn't used the connecting cable :oops: in my defence, I am used to flying the standard which doesn't use a cable. Just another senior brain fart,
I don't have a mac book, already erased contents and settings via ipad as I saw your post before, but still doesn't work. I will call the place I bought from and see if they have any suggestions.
thedrinklabsus
