Re: HOW TO: Install copper foil shield (fix low satellite co
I dunno.. mine only has literally an inch or two sticking out and its fine... Obviously th
So many diff ways people have done this... Another thing I and a few others have done is put the aluminum or copper tape up the arms a little bit.. like up to the midway point where the screws go, just before basically.. obviously still covering the initial middle part.... So my GPS module is covered by the stock shield, extra aluminum shield and then even more which goes up each arm half way. Not sure why it makes a diff, or if it even does..My theory was maybe its escaping out sides lol... so I put some up the arms.. Just don't cover the vent holes, cut a bit out so you don't cover them.. Some of the tutorial video's also go up the arms abit.
I literally tried 5 or 6 diff variations till I had a good result (more satts and no recording issues) and then settled on that... Was frustrating at times. Like it was good then I'd "make it better" which make it worse.. etc etc... then finally had a good stable result. When its "fixed" and you click record you should not loose a single satt.. The fact you don't get as many satts could be based on your location. I always tell people to try a few diff spots... but yeah you have a little work to do if you are losing satts when clicking record, so fix that up then worry about the amount you get.
Sounds like you are definitely on the right track and making good progress.. Try cover the arms as I have described and I guess cover the cable if you like.. I don't like doing to much at once because then you don't know what actually fixed it, but in the grand scheme of things, who cares as long as its fixed
Good work though
And to think... 24 hours ago you told us you weren't the type who mods there own equipment!
BTW - Are you using aluminium foil, like the kitchen stuff ??? Not sure if thats the best to use.. or if it makes any diff ?? Can anyone chime in here on if they are using aluminium foil, and if it works as well ?? I used this weatherproof aluminium tape stuff.. one side was aluminium.. then there was 1 or 2mm of squishy bit then the other side was the tape. It was originally intended for fixing leaks in outdoor metal pipes or something like that ? Some also swear copper is better, but from what I'd seen people had just as good results with either alumin and copper.. but yeah. maybe not foil if that's what your using ?
