40Mbps is nothing. Check out one of my first records at beginning of this year. And yes, it is Phantom 3 Standard with first firmware i got it. It could do almost 90Mbps.
Code:
General
Complete name : D:\Phantom 3\Vid_001\Phantom 3.mp4
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42 (mp42/mp41)
File size : 121 MiB
Duration : 11s 567ms
Overall bit rate mode : Constant
Overall bit rate : 87.8 Mbps
Encoded date : UTC 2016-01-18 21:49:15
Tagged date : UTC 2016-01-18 21:49:15
©TIM : 00:00:00:00
©TSC : 30
©TSZ : 1
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : [email protected]
Format settings, CABAC : Yes
Format settings, ReFrames : 3 frames
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Bit rate mode : Constant
Bit rate : 87.8 Mbps
Nominal bit rate : 100.0 Mbps
Width : 2 702 pixels
Height : 1 520 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 30.000 fps
Standard : NTSC
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.712
Stream size : 121 MiB (100%)
Language : English
Color range : Limited
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : 40
Source duration : 11s 610ms
Bit rate : 77.6 Kbps
Channel(s) : 2 channels
Channel(s)_Original : 1 channel
Channel positions : Front: C
Sampling rate : 44.1 KHz
Frame rate : 43.066 fps (1024 spf)
Compression mode : Lossy
Stream size : 110 KiB (0%)
Source stream size : 110 KiB (0%)
Language : English
