For me at least, the wheeled case was a solution for airline travel as it is tough enough to be checked in safely as in pretty much anything , including the backpack, the Solo is over the carry-on size limit.
The handy thing with the P4 though is the case it ships in is comfortably inside the carry-on limits so that makes the need for a hard case much less obvious as I agree, the backpack solution is way easier if you do actually have to carry it any distance especially over rough terrain.
The risk is that without direct support under the arms, when you shut the case and put pressure on the motors, you are actually stressing the arms.
I agree. they are not cheap.Should I complain? It kind of bothers me a little. I would prefer they fix the foam and send me a new insert
How hard is it to fly with a Phantom 4
Yes, that's a good point.I've not yet flown with it, but if it is in the case it ships in I'd expect zero problems as it is small and will fit under a seat or in the over-head with ease.
Foam or gimbal lock. I like the foam for speed and you don't need the gimbal lock if you keep the foam. At least on mine and seems GPC didn't want us to use the lock because they didn't cut the foam for it.
I have the non-wheeled case and I do not think the motor fitment is an issue (unless you intend to store your Phantom with the props on). Here's a photo of the top of the case lid:
The blue section (the middle of the lid) flexes a bit when you push on the top with a moderate amount of force. The red section does not flex at all. The motors are all housed below the red section.
They are close to the edge of the blue area, so I don't think it's going to flex much (if any).I think this is true on the front of the case but the motors in the back are under the blue flexible area.
Im sending mine back. Are you saying that they are replacing the foam for the case that we have? I LOVE their product and don't want to by some other brand but for the price I feel it needs some work. I have the non wheeled version.I've been in contact with GPC for the past couple of days. They've figured out some better spacing and have shimmed up some areas to provide a more proper fit.
I received a preview picture of the deeper foam cutouts which envelope nearly halfway up the motors. It looks AWESOME. They've also widened up the battery slots by 1/32" to prevent that occasional catch on the plastic lip of the batteries when you place them inside.
They've also confirmed that the interior clearance of the COMPACT case has 3/8" from top of the motors to plastic lid. That snugness is provided by the foam.
They're updating their descriptions on the website to emphasize that the Compact version is intended for those who want easier options for air travel and slimmer storage. It's truly a fantastic case, but I personally prefer the larger case with more room for my bits and bobs. Upon inspection before I boxed mine back up, I don't doubt that it shall provide more than adequate protection whether it be sitting in an office under a desk or slogging through muddy water on the other side of the globe.
Thanks so much TBDGR for the upfront work. What I want is to keep the case and have replacement foam. What did you decide to do?Send an email to [email protected] with your order # in the heading. They'll hopefully respond soon and get the ball rolling for you. Whether you wanted the larger cases or replacement foam, they're there to make sure you're satisfied. [emoji106].
Good Luck brother!
I'm curious. Are they using the exact same size case as their p3. I made a case from an old pelican case I had laying around. My p3 fit perfectly in it. When I returned it and got the p4, I ordered new foam to make another one for my 4, but the case is not tall enough. I have to buy a whole new case. I read a lot that the 4 and 3 were the same height before anyone had their hands on one and that's what I based my case dimensions on. I wonder if they did the same thing and prematurely started manufacturing these cases. Either way, glad to see they figured it out. I'm going to order one as soon as we have confirmation they are good.I've been in contact with GPC for the past couple of days. They've figured out some better spacing and have shimmed up some areas to provide a more proper fit.
Also has wheels and extension handle.Got mine from RC Junction | UAV, Multirotors, and Drones was delivered yesterday. Nice case for the price.
Those are nice. I'm going to look at those too. Can you post some pics of the inside?Ugh. My app just crashed and deleted my lengthy response. Lol. Here's a photo of my p4 compact and my p3 full size stacked on top of one another.
The new Props-On case for the P4 will be the same dimensions as the P3 Props On case
