How slow and how fast?
What was the prevailing wind when you noticed this?
What mode were you flying in?
AD
Wind was not bad at all. When I fly in reverse speeds are very faster.Forward speed is half of reverse speedHow slow and how fast?
AD
Do you use a gimbal protector?Some body please help me.I have a phantom 4 that forward speed is very slow.How ever reverse speed is very fast
As noted above switch off OA and try that. You'll probably find a significant improvement.Did anybody find out the answer on this? My P4 just back from repair (a system board they said) and flies only about 5mph forward in P mode but normal speed backward. Thank you!
Is there a gimbal guard or something else blocking the downward sensor view?VPS just randomly goes to 0.0-0.1 value and descends slow.
It's got nothing to do with the compass - leave the compass alone.Or compass calibration?
Go to DJI Flight Log Viewer | Phantom HelpOk, what data do you need? Im little new in DJI ecosystem.
Did you also disable the downward sensors? According to this data set, you did. That said, with these disabled the aircraft should not climb as it appears to have done. Your RTH was set for 19 meters and you were already above that when you activated RTH. This may indicate an issue with the downward sensors. It is possible that they could be reporting erroneous data, although the data set here does not actually show that since they appear to have been disabled.I also experience problems with RTH... I set my RTH alttitude to 40m but when I press RTH its start facing me and going up...
I tried record that flight from LOGDid you also disable the downward sensors? According to this data set, you did. That said, with these disabled the aircraft should not climb as it appears to have done. Your RTH was set for 19 meters and you were already above that when you activated RTH. This may indicate an issue with the downward sensors. It is possible that they could be reporting erroneous data, although the data set here does not actually show that since they appear to have been disabled.
