follow me different
Way points works well but when I try "follow me" it gives the message." Follow me invalid try again" anybody have the same problem?
Its best to exit "F" mode between using different "F" mode functions. I'm guessing you did a waypoint mission then went right into a POI mission.
I did exit way points first as you suggest but still no follow me. I also landed restarted and tried "follow me " only but still no response. It is the first time with a cellular Ipad mini 2 so at least I know the GPS is working. I will try and again with a fresh battery.
Strange. Is the window popping up to start the POI mission? At what point or step are you getting the error?
I tried again this morning with a fresh battery. And restarted the app this time the Follow me worked fine. Also I could fly again the waypoint routes I had set up yesterday. A reboot was all that was needed.
Reactions: III% Streve
