"firmware v1.8.0.0 not support" message in log
Guernsey
Hi,
Should I be worried about a "firmware v1.8.0.0 not support." message in my firmware log?
The result file on the SD card appears to show that my firmware is current:
========== 2016.07.05 11:18:47 =====================
Packet: P3X_FW_V01.09.0060.bin
Result: Abort.
The firmware on the SD card is identical to or older than the current firmware on the aircraft.
Thanks.
[00012574]========== 2016.07.05 11:18:48. boot(0) ============
[00012628]Packet [C:\P3X_FW_V01.09.0060.bin] detected, card sn [0x132725a8].
[00012685]Packet upgrade start...
[00012743]Packet checking...
[00012902]Packet vlink 01.09.0060 <-> 01.08.0080.
[00012960]Record vlink 01.09.0060 <-> 01.08.0080 (flow = 0).
[00013016]Done.
[00013073]Version checking[1]...
[00013156][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013237][03 06][00] v2.4.20.18 -> v2.4.20.18
[00013299][04 00][00] v1.44.0.0 -> v1.44.0.0
[00013437][11 00][00] v1.8.0.0 -> v1.8.0.0
[00013551][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00013606][11 01][00] v1.8.0.0 -> v2.0.0.33
[00013734][12 00][00] v1.10.0.0 -> v1.10.0.0
[00013844][12 01][00] v1.10.0.0 -> v1.10.0.0
[00013949][12 02][00] v1.10.0.0 -> v1.10.0.0
[00014076][12 03][00] v1.10.0.0 -> v1.10.0.0
[00014243][15 00][00] v1.1.2.0 -> v1.1.2.0
[00014341][17 00][00] v1.1.1.7 -> v1.1.1.7
[00014483][17 01][00] v1.0.2.7 -> v1.0.2.7
[00014560][19 00][00] v255.255.255.254 -> v1.0.8.96
[00014616][01 00][00] v1.30.5036 -> v1.30.5036
[00014673][01 01][00] v1.30.5036 -> v1.30.5036
[00014743][08 00][00] v0.13.0.7 -> v0.13.0.7
[00014824][09 00][00] v3.0.0.10 -> v3.0.0.10
[00014882]Packet upgrade cancelled at version checking.
If you're also seeing the expected firmware versions in the "General Settings" --> "About" section of DJI GO, then all is well.
DonT
