Easy Battery Mods
Yes you can use non-oem batteries with your oem battery. This gives you extended flight times
What is the estimated extended flying time? I don't expect an accurate answer. Just an estimate. I have a P3P. Thanks.
Usually 6 to 10 minutes depending on conditions
Thanks for posting the info. I may consider this. But, I'm guessing that you have to have two batteries in order to balance the AC. After looking at the prices, it would cost in the neighborhood of $212.00 USD. Is this correct?
[EDIT] Also, how does it connect to the existing batteries or the AC?
The P3 interacts with the battery and the battery firmware. It won't use a battery that does not contain the OEM firmware. How does this modification get around this?
Edit: clicked on the link containing the actual information on the mod. Now I understand.
Have you tried the easy mod battery setup yet? If so, can you post a picture?
You can easily make your own clips for $10. Here is my setup with a Multistar LIHV 4S 5200mAh. Works great!
Thanks for the info. Are you using 1 or 2 extended batteries? How are you holding the batteries on the Drone? Can you turn the Drone upside down and take a picture for me?
Thanks,
Cori
Thanks,
Cori
Replied to your PM
VPS is pretty much useless IMO so I have disabled it in the app. I wish I could remove it to lessen the overall weight.
Interesting. I have heard others with the same respect for it. Thanks.
Thanks,
Cori
That is a great setup I am in the process of doing this mod and am waiting on the battery's, I want to make the battery clip and I need to know the thickness of the cooper sheet. thanks in advance.
Doesn't this make you make a little nervous? All they have to do is touch for a second and they'll weld together and Blackhawk down. It's creative but they gotta improve it. Like maybe brushable electrical tape or something.
canadiansauna
