dirkclod
Premium Pilot
dirkclod said:That is strange as yours is wired like that picture but not in the other picture I got from page 3 he sent :?
Switch em and see . I order 2 of the 4" last nite and that shipping is a killer huh.. :lol: Twice as much as the cables . I will be taking mine apart when they get here and see how mine is wired . Pretty sure it's like in that video .
Edit / Just looked and mine are like yours :shock: Your TX does beep twice when you cut it on right ?
I did mine like in the video I posted .1st_time_flyer said:dirkclod said:That is strange as yours is wired like that picture but not in the other picture I got from page 3 he sent :?
yes my TX beeps twice....your wires in the extender are set up just like mine?!
J.James said:If you are just hooked in to one of the antenna ports in the re700 try the other one. You want to be hooked up to which ever one it is that sends and revives to the phantom and not the one that only sends and receives to your phone or tablet.
Even when I just did a regular antenna mod on my Re-700 i dint get much improvement at all out of my fpv range. So I went inside and switched the plug to the other antenna connection and instantly went from about 900 feet to over 3000 feet on the next test flight.
J.James said:It may not matter on the re500s and I do see a lot of people say it dont matter which one you use. But at least the the case of my re500 it made a huge difference. Which is also how it is on most ordinary wifi repeaters range extenders also. Some they can switch antennas for what ever one is getting the strongest signal But usually thats not the case cause that takes extra circuitry and its easier for who ever makes any of them to just have it so one antenna sends and receives from point a to point b and then to or from point c from point b
But also like others pointed out even if on the right spot still make sure the pin is in and that the connector is down all the way. Cause not only will it not work good if your antenna is not plugged in or having a good connection. Also a lot of different types of transmitters can burn out if they are run with no antenna connected. Which would suck way more then just not having the right connection. Some times you can have it one all right and straight then even just closing the extender can push on the wire and cause the connector to lift off and move. Which is why its also a good idea if you know you have it were you want it and down all the way to put a tiny dab of some thing on it to glue it down. like how dji uses the drop of silicone. Which also not only keeps it in place but I also think it may help some with keeping the contacts from ever corroding and not makeing good contact. Which even that can also make a big difference in antenna connections. a lot of serious radio people even go as far as to use deox-it on all there antenna connections just to help ensure the best conductivity and contact. Even a lot of manufactures and the areo space industry use it on every connection.
Thanks for chiming in with those tipsFPVLR said:guys, the u.fl connectors are very delicate, and ruining a cable is too easy, you just look at it the wrong way and it's done.
To insure a good install, remove all the junk under the board, including all copper tape and square patch antennas.
I like to start with a clean extender.
The most important thing is when you place the u.fl connectors over the male ones on the board, you need to really center it prior to pushing, and if it does not snap in place, pushing too hard can ruin the cable. 99% of all issues are fixed by replacing the u.fl cables.
