Hm, the GPS nav system in my car does not have a compass (as far as I know). When the car is stationary, it doesn't know the heading (the direction of the front of the car). But as soon as the car starts moving, it will be able to display the current heading on the moving map.
If combined with an autopilot, it would be able to turn the car to a predefined heading and start driving in that direction (bad idea for a car, but should work for a lost drone).
//Tom
The amount you rotate is irrelevant. Just nudge to the right a little bit and go forward. Compare the new coordinates to the old and rotate & move based on that. Repeat. It won't be pretty or efficient, but the drone will move toward the RTH point.Rotate a certain amount? How can it "rotate a certain amount" without a compass?
If you want to nix the compass
Okay. So you didn't mean "rotate a certain amount." You meant "rotate it a little bit." So you "nudge the aircraft to the right a little bit". Okay? I'm using your words. I suppose you mean you want to "nudge" it clockwise a little bit. So you do that. Okay? The craft is now rotating clockwise. Okay? Stay with me. You still have no compass. What's next?The amount you rotate is irrelevant. Just nudge to the right a little bit and go forward. Compare the new coordinates to the old and rotate & move based on that. Repeat. It won't be pretty or efficient, but the drone will move toward the RTH point.
The drama that I didn't have to deal with is altitude. Couple of different options, none of which are bullet proof. All of which are probably better than a random flyaway.
My take is that he is effectively saying it could have been designed sort of like the children's game of Hot and Cold. After ascending to the preset RTH height, the Phantom could be designed to move a short distance and then compare it's current location to the home point while GPS keeps it from drifting. Is it getting closer to the home point? Yes, you're getting warmer. No, you're getting colder you went the wrong way try again. If no, the Phantom rotates a number of degrees, moves a short distance and then compares again. Closer to home point this time? Yes, you're getting warmer keep going for a while and then repeat the process. Now you're getting very hot, etc. After a few of these comparisons, the Phantom could determine a reasonably accurate direction back to the home point and then stop to compare less frequently along the way.Okay. So you didn't mean "rotate a certain amount." You meant "rotate it a little bit." So you "nudge the aircraft to the right a little bit". Okay? I'm using your words. I suppose you mean you want to "nudge" it clockwise a little bit. So you do that. Okay? The craft is now rotating clockwise. Okay? Stay with me. You still have no compass. What's next?
Car navigation systems do have compass.If you think it's easy to determine heading from GPS points because your car does it, there's an important difference you need to consider:
Your car is just a little less likely to drift in the wind. Hopefully, it's doesn't drift at all! And actually, it's more likely that your car does have a compass in it if the navigation system is any good.
The compass is there for a reason. If you want to nix the compass, start looking at RTK which is very precise but equally expensive. In the meantime, the compass is essential. No way home without it.
Bingo. You put words in my mouth way better than I take them out. Thanks.My take is that he is effectively saying it could have been designed sort of like the children's game of Hot and Cold.
It's not clean, but perfectly doable. This seems to be an awfully reasonable RTH when the world (other than GPS, of course) has come to an end. When the execution is controlled by a number of user-selectable variables, you have the best possible fail safe.
Wrong. But to each his own.It's not reasonable, and as I pointed out in post #29, it's not doable.
I was using your example. You said you'd rotate it a certain amount. Then you said you'd rotate it a little. Rotating it will not work for obvious reasons - you (or your algorithm) will never be able to stop the rotation. Forwards would be backwords. Left would be backwards. Forwards would be left. Forwards would be right. Forwards would be right again.. Left would be forwards. And so on. You'd be helplessly lost.Wrong. ....
Just had compass error last week 9,000ft away from home point. DJI go showed where the bird was on the map but orientation of the bird was not correct in the app. Switched to ATTI mode and relied on visuals in the FPV feed to navigate back home and used the map as a reference to make sure I was heading in the right direction. I'm not sure if RTH would have worked because DJI Go was reporting that my drone was facing west the whole time while I was flying actually pointed and flying in a northwesterly direction. Check out the video
