Direct charging P2V batteries
New Mexico USA
Don't know if this has been posted before, but thought I'd ask. If all the smarts for charging the P2V batteries are self contained and the supplied "battery charger" is just a power supply, would it be possible to just charge off of a 12v car battery and eliminate the need for using a power inverter and the DJI charger ?
You need, of course, a battery with enough capacity and be aware of over charging or use a current sensing device to cut off the charge.
1dr1 said:
Just thought I'd bump this since I got no replies. Any opinions, thoughts??
I can't honestly answer your question using a car battery direct, but I did a test last night charging a P2 battery on an Imax B6 quattro charger and it worked. I made an adapter from the P2 to XT60 connector (std P1 stsyle) and charged at 4amps - took 64 mins from 11.4v to 12.8. The Imax B6 is a DC charger that can be clamped to a car battery.
brianklenhart
