Cross Restricted Zones
I took the plunge a couple of weeks ago and purchased the + been quite nicely flying around and using the RTH function etc.
Using the APP Ive tried to program way points but on each occasion it gives an error message of unable to cross restricted zones. Having looked at the restrictions I do not seem to be in them,
Anybody have any ideas
No, have not seen that error. I normally do not use ground station but if you try to set a way point outside of the max distance, it will not allow you to proceed. Could that be your restriction?
I do not think its a distance restriction as Im only setting no more than 100 ms as still quite a novice
Are you on 3.10? I believe it's a 5 mile radius around airports that you cannot fly in.
canadiansauna
