Crashed... Where is replacement landing gear?
Looked for it on helipal last night and popped right up. Now it's not there... Does anyone have a link to it? What about instructions on how to install?
Crashed pretty hard this weekend... Gimbal seems ok, landing gear cracked, case has a small blemish. Compass error right now but I'm looking for the landing gear because that's the only thing that actually broke.
You can buy landing hear on Amazon here.
I doubt instructions are included. If the wires housed inside of the landing gear are still in good shape, you could probably use the existing wires and forego having to open up your Phantom.
Reactions: maseman88
Sorry, I see its white. Lol
Yep. They are OEM :)
Excellent. So, I'm assuming that will fix my compass issue. The bird flies and is rock solid after a 60 foot crash and fall in the forest. I can't believe it. Msinger, any guides on how to open her up and do the replacement? You know your stuff
The compasses are housed inside of the land gear, so it's possible. Or, perhaps the compass wires are just detached on either side. There is a connector on either side of each wire that snaps on inside the top of the landing gear and inside of your Phantom.
I noticed it was disconnected and was able to reconnected it with needle nose pliers. No compass issues now.
Reactions: Jussaguy
When you replace or fix, can you post? I had a recent fall and it ajarred the landing ski a bit.
No problem. I'll let you know how it goes.
The last pic shows the re inserted collar that the screw will go into one the new arms are here. I can't believe it yanked it out of the lower shell.
Very easy to take apart with tweezers and a needle nose
How were the legs taken off in the first place. Were they snapfit or screwed? There is a piece that became ajar on mine at the very base of the phantom body leading into the landing gear
you pull those covers off and there are 2 small allen head screws. You undo those, then you have to use tweezers to scrape come silicon off that they use to make the the cables attaching to the legs dont come off. It was very easy and i'm confident it will be good to go. May even order a case in the future if i get sick of looking at that imperfection.
Reactions: Geeno
Thanks. So it sounds like i just need to channel my HULK pinch to get the cover back in place. Its like having a new car and seeing a dent. I wonder how much more damage would have occurred if I didnt have the foam on the landing gear to cushion it somewhat.
The covers are very easy to put back in. Just tweak the landing gear outward and it clicks into place.
All updated with the new firmware. Gonna fly a litchi mission in a couple minutes. Flies perfectly
brianklenhart
