control function while in ground station
Question....during a programmed flight in ground station can you use the controls for a slight path or altitude adjustment?
The only control I use is the camera tilt. Thanks
No. Your Phantom will follow the programmed path exactly. The only thing you can do is pause or cancel the mission.
You can also control the tilt of the camera.
src72
