battery error P3P not charge
Montevideo, Uruguay
Hi,
the problem is that P3P battery does not charge. The 1st Led light is flashing and not Charging. I have left it for more than 1 hour charging but not work.
When I try to power on the battery, I get the red power button come on and then the bottom green light flashes a few times... and then the battery powers off.
It has less than 10 cycles
Any suggestions?
Thanks!
Hi,
Any suggestions?
Thanks![/QUote
i have a P4 battery which does exactly what the same as your P3 battery. Once these batteries sit idle and not charged for a perod of time the become non functional..the circuit wont allow recharging. I have opened up my battery and tried resetting it by disconnecting balance wires from the board..with no joy!
The DJI batterys are under a 3 month warranty....is it over that period ? and how has it been stored with HOW Much charge ?
The battery was stored at 20% for about 3 months. Surely is completely discharged.
Yesterday I thought about opening it, but I left it around 15 hours charging and today is full charged.
I guess I was lucky!
Thanks for the help
Reactions: MotorCycle-Man
Just be careful and watch the battery levels during a flight.......Hey keep it low and close...Just in case the battery might fail you in flight extremely FAST...Don't trust it for a while.....keep it low and slow and CLOSE....Good Luck javier*
20% is Too Low to store a battery..... when storing at FULL charge and after 10 days......the battery will internally drop to a lower level for a safe storage..
Reactions: sarniac
irish_phantom
