- Joined
- Dec 11, 2016
- Messages
- 9
- Reaction score
- 1
- Age
- 41
Local hobby shops want a part number. Im pretty sure it doesn't exist. Will DJI have just this piece maybe?
If that's the case and it happen to me *touches wood* I would just be putting a bit of tape over it. Screw paying out for a new leg!Pretty sure you will to purchase the entire leg assembly. A lot of people put clear tape over the cover to keep it in place as I have read a number of threads relating to them either falling off or being knocked out after a crash/hard landing.
I had that part pop off when I made a bad landing and didn't notice for several days as I also chipped the end off one of the props, since replaced. I found the part against the fence it had hit (not violently), picked it up, popped it back on and bob's your uncle.
Question for you... Do you typically land using the RTH button/feature?
I lost the same part, and I suspect it was from a previous hard landing in the grass (I do recommend manual landing, not auto). I contacted DJI, asking for a part number and to see if it was available separately. My P4 is still under warranty and they sent me a set of replacement covers for free. Here is the part description: Phantom 4 landing gear antenna cover (no part number to be found). I just told them it fell off during flight, which was true, sort of.... I sent them a picture, similar to your photo, my invoice, and a description of the problem.
I always use RTH, or auto land.
Thanks for the quick reply! I don't really want to cut anything off yet, but I may have to if there is no other way.Yes a real pain. I cut the little nob off about half way if that doesn't work I cut it off totally and used silicone to hold it back on, I squeeze some inside then press it to the silicone.
