Android screen recording. How big are the video files?
Hi folks,
I'm looking at buying a Nexus 7 (2013)...either the 16 gig or the 32 gig, for use with the P3, including screen recording of the flights. I won't be using the tablet for much of anything else, it will mostly be dedicated to the P3.
Question...
About how big are the screen recording file sizes?
Thanks...
Bill
Huh? Okay, I'll state the obvious.... it depends on the amount of time you record. The longer the recording time, the larger the file.
Normal is 650MB. But I have been having trouble lately with go app freezing when using screen recording. I used ez screen recorder without problem but after a while it started freezing and reboot. Switched to a screen recorder called Unlimited Screen Recorder and it was fine for a while. Then same thing happened. I have 9GB free on the 16GB Nexus 2013 on Marshmellow 6.0.1.
Without screen recorder I have zero problems.
depends on the app u use to record with but 16gb should hold at least 16 flights worth of footage.
Trackman1...so you are saying that a "full flight" (15-18 minutes?), uses 650mb?
Thanks...
Bill
It was capture by Unlimited Screen Recorder (free)
Unlimited Screen Recorder - Android Apps on Google Play
Thanks...
Bill
Here is the complete file info from an 18min recording done at 5000Kbps. 1728 x 1280. File size 647MB
General
Complete name : D:\My Documents\My Pictures\2016\02\6th Flight Pilot View.mp4
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42
File size : 648 MiB
Duration : 18mn 6s
Overall bit rate : 5 000 Kbps
Encoded date : UTC 2016-02-17 16:24:35
Tagged date : UTC 2016-02-17 16:24:35
com.android.version : 6.0.1
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : Baseline@L4
Format settings, CABAC : No
Format settings, ReFrames : 1 frame
Format settings, GOP : M=1, N=31
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 18mn 6s
Bit rate : 4 982 Kbps
Width : 1 728 pixels
Height : 1 080 pixels
Display aspect ratio : 16:10
Frame rate mode : Variable
Frame rate : 28.708 fps
Minimum frame rate : 1.164 fps
Maximum frame rate : 409.091 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.093
Stream size : 645 MiB (100%)
Title : VideoHandle
Language : English
mdhd_Duration : 1086654
Audio
Format : AMR
Format/Info : Adaptive Multi-Rate
Format profile : Narrow band
Codec ID : samr
Duration : 18mn 5s
Duration_FirstFrame : 1ms
Bit rate mode : Constant
Bit rate : 12.8 Kbps
Channel(s) : 1 channel
Sampling rate : 8 000 Hz
Bit depth : 13 bits
Stream size : 1.66 MiB (0%)
Title : SoundHandle
Writing library :
Language : English
mdhd_Duration : 1085640
Trackman1...thanks so much for that...just the info I needed...OK...looks like a 16gb Nexus 7 (2013) will do fine for me.
I appreciate your effort.
Thanks...
Bill
