Fanti said:Yes, up and up. Try it.
Video link was fine. RC was a bit shaky, meaning it got lost several times.
gpauk said:A sort of side issue -- what device were you using for the data display, and what did you use to take the screenshot?
Lovely view though... Where in the world are you? When we get cloud that low you'd never get to the other side of it!!
MrFlats said:gpauk said:A sort of side issue -- what device were you using for the data display, and what did you use to take the screenshot?
Home Button + Lock Button pressed at same time will do a screen capture on iPhone.
Fanti said:Flying high...! Of course NOT in controlled airspace.
MrFlats said:Sorry upload failed it was too big. Here it is again. Sent from iPhone.
Fanti said:Hi guys,
it was in a sort of no fly zone in South Africa, where aviation is forbidden. So I could go that high.
The whole trip up and down took about 12 minutes.
Wifi is not the problem, TX range is. When I fly away though, I hardly have 200 m range. Odd
No mods to any systems, all stock.
I interrupted the going home process.
Yes, straight up from the beginning.
Next project: to exceed 1000 meters.. And then 2000 ;-)
Why don't you all try ho high you can go and we share the results here.
Even if you loose TX and/or wifi, nothing will happen,worst case it will auto come home.
