djiatl said:oh and make sure the tx and rx antenna are both either rhcp or lhcp.
I personally like the Circular Wireless or 5.8 GHz Airscrew Cloverleaf Ultra Antenna (RHCP) IBCrazy
djiatl said:Alex Greve (IBCrazy) is a highly respected innovator in the field.
Here is his website: http://videoaerialsystems.com
See here as well: http://www.rcgroups.com/forums/showthread.php?t=1388264
Pretty much sets the standard..
skeeter said:Does anyone know if the stock DJI AVL58 Tx antenna is RHCP or LHCP? Or??
I ask because I have a Lilliput 664 that has a female Rx antenna port and the DJI AVL Rx antenna is female also. I'd like to avoid an adapter if at all possible...
ianwood said:You may be mixing up right and left hand circular polarization (RHCP and LHCP) with SMA and RP-SMA which are the connectors. The Lilliput is SMA. I don't know about the AVL58.
For the rest of you, when I bought my set up I looked at the expensive antennas and thought "meh, it's just a piece of curled up wire" and bought myself a cheap set of eBay cloverleafs (http://www.ebay.com/itm/141120723324). Now, I'm wondering "maybe some wire is curled up better than others" and considering paying IBCrazy prices for a better piece of wire.
Who has upgraded to premium antennas from the not so premium cloverleaf antennas and was there a worthwhile difference? And which of the myriad IBCrazy ones should one consider?
The AVL58 is RP-SMA.ianwood said:skeeter said:Does anyone know if the stock DJI AVL58 Tx antenna is RHCP or LHCP? Or??
wkf94025 said:AvidPhoto,
Please advise as to how that works out. I am in same boat: P2 with Fatshark Attitude and looking to improve video range.
Kelly
goldfishrock said:A lot of the cheaper antennae you see on ebay aren't particularly good as they haven't been manufacturered to the tight tollerences that they need to be for optimum performance. In my opinion it's better to shell out a little extra to get a quality antenna that you know has been made properly.
Tmesis said:Have you compared the two or are you just guessing that you get what you pay for?
