Whats the problem with the Vision APP?
Check your wiring. Sometimes the wires are not making a good contact. Check all the wires coming from the belly of the Aircraft to the camera. There are 3 (2 in fount and 1 on the right side). Also check the cable on the gimbal, make sure it's plugged in tight. Good luck.
Reactions: Lasernerd
Have you opened your bird up? Do a thorough inspection of the wiring. If you have to unplug some of the wires and replug them back in. Last, rebind your Wi-Fi again.
Scav8tor
