- Joined
- Jan 17, 2014
- Messages
- 344
- Reaction score
- 1
Winds at altitude will quickly become much stronger than at ground level. And those pretty clouds? Were they perhaps Cumulus clouds? Those are the ones with thermals below and inside them glider pilots are so fond of because the air also has vertical speed there.
If the Phantom enters a thermal which at cloud base will be (much) stronger than at lower altitude it will be sucked into the cloud. I have flown near cloud base in gliders and you have to fly a lot faster there to keep descent rate big enough to not enter the cloud which in VFR flights is NOT allowed, and for a very good reason. If the Phantom tries to maintain altitude it will slow down its motors giving it less ability to move horizontally. In a situation like that it is quite likely to be moved horizontally at considerable speed.
I'm afraid too many people have too much blind faith in the abilities of the Phantom. They are very limited in those abilities and are far from foolproof. You are dealing with many real aviation aspects when flying a Phantom and people need to acquire the knowledge necessary to fully understand these. Same as people have to do in 'real' aviation. You're not allowed to fly up there unless you have proven to have the proper knowledge and experience. Since there is no requirement (yet) to do the same when flying model aircraft it's up to each individual flying them to make sure they do have the necessary understanding.
