The version for iOS does not follow a moving object (can't speak for android version)--I just tried it for the first time this afternoon. It does however yaw and pitch the gimble as necessary to keep the tracked object centered as you fly around. It tracks pretty well--even boats on a lake backlit by the sun and glare from the water--however, get too close with too much vertical angular velocity and it will loose track pretty easy--I'm wondering if perhaps gimble pitch speed has some effect on this. I have speed set pretty low to make my manual camera pitch movements smoother; but am wondering if it's effecting Vertical Studio's ability to track; so I'll be experimenting with that later. I'm also not sure if the tracking calculations are done on the mobile device (I assume so); and perhaps using a faster device than the iPad Air I was using, would give me better results. Anyone know?
Because it does not maintain a given distance to the target, using orbit on a moving target doesn't seem to work well by itself, but does free you to adjust distance (radius) manually, and in any case frees you from having to operate yaw, gimble pitch and aircraft roll controls simultaneously. For orbiting a stationary object it's great, and so much faster and easier than other apps with POI.
