Please sir stop spreading completely incorrect information.I know for a FACT that it will. I've seen it happen. And I've seen numerous cases of it happening on this forum. There is a thread where it is discussed.
Again, prove it. I've seen it happen. As soon as you post something proving your point, I'll listen. Until then, Hogwash I say.
I do it every day and as do most pilots who know their craft. There is no need for me to do it again to prove anything. It is common knowledge in fact, so unfortunately by insisting a left stick down will stop your motors while in flight, you are showing that you don't understand your Phantom and you may be steering new fliers in the wrong direction.Oso, if your so sure, why not fly up a few hundred feet then full down on the left stick. Post the telemetry afterward. Lets get to the bottom of this. With your bird of course.
Totally confused now. Initially I thought that bringing the stick down would shut the motors down Irespective of where it is and was corrected to say this would only be the case if landed or caught? Looking forward to a definitive answer
My two cents here is that pulling all the way down in the left stick alone shouldn't stop the motors in the air. That is not a CSC command. if it happens there is a malfunction somewhere. Even if you catch the bird and try to stop the motors by pulling down the left stick, you have to hold it very steady to stop the motors.
I wasn't there so I'm just guessing. Is it possible that in all the fun and excitement of catching a falling P3 that you were distracted and didn't see what the pilot was doing with the sticks. Sounds like it might have been fun.Bud Walker, this was my understanding as well from all the verbiage I've read on the matter. Had I not witnessed it occur, I would still think the same. I watched someone drop their P3A to full descent and all 4 motors shut off, not once, but twice. 3 seconds of full descent shut the motors off both times. I was the guy dumb enough to volunteer to catch it. I'm not aware of any differences in operating characteristics between the P3A and P3P, nor of any settings that would allow you to manipulate how the motors are shut off. He was using a different app other than the DJIGO but I don't recall which one.
Although the camera of my drone is broken, it still reacts to RC commands. When I switch on the drone and hold it over my head, it shows a height of 2 m. I make the following test: I pull down the left stick to the utmost position and move the drone with my hand downwards too. The engine switches off. I don't even try to hold it stable, but move it downwards. Is this a suitable test to see whether one stick can shot down the motor, or is this not very reliable?My two cents here is that pulling all the way down in the left stick alone shouldn't stop the motors in the air. That is not a CSC command. if it happens there is a malfunction somewhere. Even if you catch the bird and try to stop the motors by pulling down the left stick, you have to hold it very steady to stop the motors.
My post was a reaction of phantomi's saying that: "Even if you catch the bird and try to stop the motors by pulling down the left stick, you have to hold it very steady to stop the motors."The act of you holding it is still exerting pressure on the leg, making the phantom think it has landed.
