I crashed my Phantom 3 Standard and had to replace a damaged yaw arm and the ribbon cable.
Now when I power on the drone the gimbal doesn't move at all, I can't control it with the controller.
I repaired the yaw arm and replaced the ribbon cable with a knock off ribbon at first and had this issue. After reading online about chinese ribbons causing this issue I went and bought an OEM DJI ribbon but after installing it I'm still having the issue
Here are some details of what I'm experiencing:
- Gimbal is not calibrating on startup.
- I am receiving picture from the camera through the app without any issue.
- the led light on the gimbal top/main board is flashing green on start up and then solid green after 5 seconds or so.
-there is a slight noise coming from the gimbal which intensifies when I move the arms and camera with my hand (not sure if this was there before the crash)
Any help would be much appreciated!
