I just purchased a used P3A and have been trying to get up to speed on the correct steps to get this bird in the air, but am having problems with a few things.
1. The RC is not connecting to the bird
2. Using the DJI GO app to connect the RC, but at the step to press the link button on the bird nothing happens, no lights or any changes at all.
3. Firmware update fail. Correct format of the card (exfat) performed in the P3A camera sdcard slot, tried current upgrade first (multiple times), then the two previous firmware versions (again, multiple times) with no luck. The Rc has not been upgraded unless the DJI Go app did it automatically.
4. In the sdcard .txt file, the date and time stamp are showing:
2014.01.01 00:00:22
A computer that has a bad internal bios/cmos battery will not retain date or time unless constantly powered on. If the firmware is current, but the date stamp on the bird is default to january of 2014, it would likely cause a failure. Is there any sort of replaceable button battery in the bird required to remember the firmware settings, and would it go bad? If that battery goes bad in a computer you lose not just date and time, but all of the custom bios settings return to default state.
Here is mt .txt file, any help is appreciated!
========== 2014.01.01 00:00:12 remo-con disconnect======
Packet: P3S_FW_V01.09.0060.bin
Upgrading ...
Result: Success.
========== 2016.07.09 20:41:39 =====================
Result: Abort.
The firmware on the SD card is identical to or older than the current firmware on the aircraft.
========== 2016.07.09 21:29:48 =====================
Result: Abort.
========== 2016.07.09 21:37:30 =====================
Result: Abort.
========== 2016.07.09 21:43:07 =====================
Result: Abort.
========== 2016.07.09 21:47:42 =====================
Result: Abort.
========== 2016.07.10 08:43:22 =====================
Result: Abort.
========== 2014.01.01 00:00:11 remo-con disconnect======
Result: Abort.
========== 2016.07.20 20:30:29 =====================
Result: Abort.
========== 2016.07.20 20:49:35 =====================
Result: Abort.
========== 2014.01.01 00:00:21 remo-con disconnect======
Result: Failed.
Reboot the aircraft and try to upgrade the firmware again.
========== 2014.01.01 00:00:22 remo-con disconnect======
Result: Failed.
Result: Failed.
Result: Failed.
Result: Failed.
Result: Failed.
Result: Failed.
Result: Failed.
Result: Failed.
Result: Failed.
Result: Failed.
Result: Failed.
Result: Failed.
Packet: P3S_FW_V01.10.0090.bin
Upgrading ...
Result: Failed.
Result: Failed.
Result: Failed.
Result: Failed.
Packet: P3S_FW_V01.08.0080.bin
Upgrading ...
Result: Failed.
Result: Failed.
Upgrading ...
Result: Failed.
========== 2014.01.01 00:37:14 remo-con disconnect======
Result: Failed.
Result: Failed.
Result: Failed.
Result: Failed.
Result: Failed.
Result: Failed.
Result: Failed.
Thanks for helping on this!
2014.01.01 00:00:22
Upgrading ...
Result: Success.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Failed.
Result: Failed.
Result: Failed.
Result: Failed.
Result: Failed.
Result: Failed.
Result: Failed.
Result: Failed.
Result: Failed.
Result: Failed.
Result: Failed.
Result: Failed.
Result: Failed.
Upgrading ...
Result: Failed.
Result: Failed.
Result: Failed.
Result: Failed.
Upgrading ...
Result: Failed.
Result: Failed.
Upgrading ...
Result: Failed.
Result: Failed.
Result: Failed.
Result: Failed.
Result: Failed.
Result: Failed.
Result: Failed.
Result: Failed.
