P3 PRO just keeps beeping...
Hello,
I have received much help from you guys going back to the P1 days. My issue right now is that my 4 month old P3 Pro, with only 6 flights on it has now decided to stop working. Here are the symptoms-
The actual bird just keeps beeping - (BB..BB..BB..BB) and flashing yellow lights.
The RC turns on just fine and my Droid turbo & iPad mini work just fine but won't show video feed and read Disconnected. I can still fly it but no video connection?
I have tried all - changing usb cable, debug usb on phone, airplane mode, new sd card, uninstall and reinstall GO app?
Also, when I try to power of the P3 the battery does not shut off right away, it blinks red and the P3 stays on for about 10sec. I have two batteries and it does the same with both?
Im at a loss and don't know what to try next short of trying to go the route of contacting DJI? Any advice would be greatly appreciated.
Check to make sure the grey ribbon cables that come from the body of the quad to the top plate of the camera are firmly seated.
When I had my camera off for repairs, I had the same symptoms with battery lights blinking red for a few seconds before shutting down...when the camera was re-installed all was well.
Can you reinstall the firmware? Just put the image on your SD-card and wait until it is finished.
Im so Stupid!! I did see a post where someone had a lose cable but didn't check, and as I was on the chat with DJI a little bit ago I happened to look in between the gim and P3 and there it was.... a disconected grey ribbon!!!! Everything is good now. I hope at least others will now see this as a solution to check.
Thanks guys!
brianklenhart
