P2 and P3A use same props?
Do a search on carbon fiber props... results not good.
Best are stock props!
Because the Phantom 3 have an active braking system, rotor blades with the aluminum hub, can be loosened and can accidentally throw a blade, while in flight. Only use the specified Phantom 3 rotor blades.
They are less than $10.00 for a pack of two.
RedHotPoker
Reactions: bobmyers
P2 props on a P3 is not a good idea. Use the correct props. There are no appreciable benefits from aftermarket props on a P3 at this time.
P2 and P3 use different props. P3 uses 9450 regardless of standard or carbon fiber reinforced.
canadiansauna
