No street names and massive lag
Using a p3 pro at the moment. I am using a iPad mini 2, wifi off, all apps shut, brand new with no other apps on there in airplane mode.
The iPad displays a very laggy jerky image which isn't the same as I have seen elsewhere.
The iPad is updated to the latest version as is the p3 and controller. Anyone any ideas why this is happening? Can't see any other issues. 20 satellites received, this happens even at short range.
Any tips welcome.
Do you have the hardware decode enabled in the app? If not, maybe give that a try.
Also, maybe try with no case if you have the Mini 2 in a case. They have been known to heat up and lag.
I didn't but I will try that thanks.
Anything else I should try? There's no case
