Multiple quads using the same radio/FPV setup
I think the answer is yes but...
I want to use the same FPV setup to run two phantoms (not at the same time). One is a visual system and one is an IR equipped system.
If I just bind the newer phantom controller to my two phantoms. I can get into the phantom assistant and calibrate and go I would think. That should
Again not meant to fly at the same time. I am not THAT much of s glutton for disaster.
Thanks...
Marc
Thanks...
Marc
I think you will need to bind it to each transmitter each time you change birds....
He is correct in having to bind each craft separately before using.
DonT
