Itelite DBS02 defect?
I have a P3P. I bought an Itelite DBS02 range extender and installed on my original remote. When I turned it on flashing red light and just continuously beeped. So, I thought my bad. Maybe I did something wrong. I bought another remote and installed it on the new one. Same **** thing. Needless to say, I am highly discouraged and about to give up on flying. This can get rather expensive. The thrill is gone. I was extremely careful on both installs. Can't imagine I would have messed up twice. Anyone have experience with a defective DBS02?
Thanks
So I might be wrong, but I believe what your seeing is it needing a stick calibration!
Does it connect to the bird? Can you see the camera in the Go app?
Mine beeped like crazy too, and finally I realized it wanted a calibration!
Have you paired the remote controller P3P?
It will not connect to the bird. I tried stick calibration and that did not fix the problem.
Okay... I see. Have you tried a hard reset on the controller and then paired it?
Also you need to update the FW on both to make sure that's not the issue
Even if the antenna was flawed, it would still connect probably unless it got ran over. These are pretty robust.
I would update FW on both, do a reset on the controller (serious of button presses), then repair
Information description is pretty thin, op. I'm guessing the bird is flashing red? You must have some connection if you could try stick calibration. Lack of information is too confusing. You could have a bad cable or antenna, or you might have broken a cable or cable connector on your first attempt and that's why the same thing is happening to the second remote. I'd reach out to support for the kit. They'll know best.
DonT
