interference
Mexico city
why does my p3s always detect interference even when in an open field?
it appears on the left side of the screen a warning message saying "warning strong interferance detected, be careful when flying long distances"
why does this happen and how do i fix it?
btw i just created my account yesterday so...
that usually is saying metal of some type is nearby
watch,
chains
cell phone keys etc
good luck and have fun flying
watch,
chains
cell phone keys etc
Isn't that WiFi interference, Not magnetic?
Rod
Generally WiFi signals where your are flying, routers, and all the devices that are communicating to the routers via WiFi.
For android check this out.
Wifi Analyzer - Android Apps on Google Play
This app shows AP's, it doesn't show you any devices that is connected to the AP's
Could be one, could be more or a lot more.....
Rod
Rod
it may be same or similar for that as well.
I thought I had seen that message at time or so when
I fired my p3sup on bench too close to an old monitor.
to OP
if it does it every where its one of 2 things:
the quad itself has an issue, bad/loose connection, bad part, etc.
something on or near you when you fly.
or maybe for fun try a different device to use to fly and see if any thing changes
edit
try a different channel in the app
Rod
But what app do yo recomend of i have an iPhone?
Rod
at one point I would get a interference from a high power enterprise AP I had testing in the house when within 15 or 20 feet of it.
once away it was fine.
maybe he could manually try a different channel via the app, that may answer.
I have the same problem, I never had this problem until I did the last firmware. I have gone to a big open field and still get the same message. I have read it's in the firmware and dji needs to fix this problem.
I just think it's detecting wifi interference in the area that was always there, but not being reported. How many of you remember to turn off the wifi on all cell phones on you (not the one you might be using to fly if it's a P3S) or others with you when your flying.
It doesn't matter where you are, the air is saturated with electro-magnetic signals (cell phone, radio, tv, wifi etc) It is just a warning to make you aware, DJI cannot do that much about it. :)
src72
